Front end judder when braking?
Posted: Sat Oct 06, 2012 8:12 pm
by Kawasaki23
Hi,
Bought an L9 2002 on Saturday, Loving the bike however when braking there is a judder coming from the front end, just wondered if anyone has had this problem before or knows what the problem could be?
Re: Front end judder when braking?
Posted: Sat Oct 06, 2012 8:16 pm
by bude-zxr
Warped discs knackered brake pads???
Posted: Thu Oct 25, 2012 12:34 am
by Spikey12
I have the very same problem, I suspect warped disks.
Posted: Tue Jan 08, 2013 7:35 pm
by syihabuddin
The judder rate, is it proportionate to your speed?
If it is, its your discs. If it isn't there are more cumbersome areas to check. Lets start with the discs shall we?
Posted: Wed Jan 09, 2013 8:53 am
by banner001
can be head bearings too.
Posted: Tue Apr 30, 2013 3:36 pm
by Jamesdavies120
Hey I've had the problem as well. ( all fixed now)
Discs, brakes as Callipers are unlikely as its only harder braking... Plus to worp discs must be hammering the bike,
Anyway check your tyre pressure, easy thing to miss.
Cause; front end bottoming out on hard braking,
Solution; I solved my judder by hardening the front end compression, stock setting was to soft, adjust the 22mm nut in the top of the fork, wind it down by 1 line ride it and see, if it doesn't help go another line.
Can use a cable tie on te fork to measure how much it's compressing.
Also make note of the current setting , line it's currently on before adjusting. Mine was on 5, set to 3 now.
Failing this, check last time damper fluid was changed?
Posted: Tue Apr 30, 2013 9:07 pm
by banner001
^ more terminlogy than anything, but what you are doing is increasing the preload...not compression damping.
