EBC disc fitting problems
Posted: Sat Sep 17, 2011 11:16 am
by hendo1990
Hi
I've recently bought a set of EBC discs for my L9 and I am having some trouble installing them.
The problem is that the discs do not sit central in the callipers which stops the wheel from moving. Do the discs need spacers to allow them to run central in the calliper?
Many thanks
John
Re: EBC disc fitting problems
Posted: Sun Sep 18, 2011 9:18 pm
by Tirpitz
No.
Presuming you have got the right discs which match the model (because H discs are different from L discs). And presuming everything was fine with the old discs you took off.
The discs, being new, are probably thicker than the ones you have taken off, so firstly you will need to push the pistons right back into the calipers. Do this with the brake fluid reservoir cap off (do it SLOWLY with a rag around it) and remove excess brake fluid with a syringe as required. Once you've got the pistons right back in put the calipers back on and pump your brakes to move the pads up to the new discs. Be careful as you do this to make sure the brake fluid reservoir does not run empty - top up with fluid from your syringe as you go. When you've done you should have your reservoir fluid level about halfway between the max and min levels. Put the top on and everything should be fine.
If something is still wrong you need to be talking to the people you bought the discs from, cos obviously they're the wrong ones.
Let us know how you get on.
TBH I'd have gone for OEM.
Posted: Mon Sep 19, 2011 4:20 am
by Mori Man
Offset on the discs is the same for most Kwak bikes using them , zrx1100,1200,GPz, Zephyr etc..... just the patterne changes on discs holes and the carrier hubs.
H = 300mm diameter
L = 310mm
Offset is same as you can fit 310 to H and use 310 adapters on calipers.
Only spacers used on the discs are the plastic ones between disc and wheel to stop sweating that causes alloy oxidization as the older carriers are steel.
OEM discs are made by Sunstar who have supplied to all the Japanese manufacturers since about 1969 and they make their own range to fit too with alternative patterns on discs like slit cuts
When my discs go I will be getting them for sure
Haing thicker discs than OEM wont cause misalignment so pushing the pistons back in wont cure them not being centred , you could feesibly use extra plastic spacers if your only talking baw hairs - assuming the need to be moved further out from wheel.
MM!
