Brake Discs
Posted: Mon Dec 21, 2009 9:20 am
by SOILZX
I've been having a search round and in 1 of the topics on here i saw, it could be possible to fit ZX7R front discs to the 400? Can anyone confirm this?
I know there 10mm bigger, but i'm looking at brake options and like the idea of gixxer 6 pots (pads will hang off standard size discs) and thinking of changing discs anyway.
Re: Brake Discs
Posted: Tue Dec 22, 2009 12:24 am
as far as my memory serves me the zx7r are 320mm as opposed to 310mm on the L model so you will either need to change the caliper or use jack up kits to mount the originals, then you need to worry about clearance with the wheel.
why do you want to change them?
Re: Brake Discs
Posted: Tue Dec 22, 2009 8:09 am
by SOILZX
I'm looking at putting gixer 6 pots on it (have the calipers and sleeves already and some mounting bolts on order), but gixer thou's have 320mm discs, so the pads will hang off slightly, just looking to see if i can eliminate the pad hang off realy.
Re: Brake Discs
Posted: Wed Dec 30, 2009 8:14 pm
by bendog66
the pad doesn't hang off. i can take some pics of the wear on my discs if you wish to prove it
Re: Brake Discs
Posted: Wed Dec 30, 2009 11:55 pm
by SOILZX
Na, thats fine then fella
