wheels spindle diameter ?
Posted: Thu Jun 25, 2015 7:56 pm
by Tricky
anyone know the outside diameter of the wheel spindles on an H and L ?
cheers.
Re: wheels spindle diameter ?
Posted: Fri Jun 26, 2015 8:45 am
by Dominik
All L-Models have 20mm diameter front and rear, H should be the same but I donĀ“t know for sure.
Most Zx6r s have 25mm.
Posted: Sun Jun 28, 2015 10:05 pm
by Tricky
thanks for the reply Dom, but H are different size from L.
Posted: Mon Jun 29, 2015 11:16 am
by zimm
H2 is the same as L, H1 is smaller..I'll try to remember to check later for you.
Posted: Thu Jul 02, 2015 10:03 am
by Ewetea
Rear spindle on H1 is 17mm diameter. Front spindle on H1 is 20mm, but has larger diameter fittings at each end of 27mm diameter, compared with 25mm dia for the L1. These fittings engage with the holes in the lower fork legs and have an internal hexagon for tightening. Thus an H1 spindle cannot be used on L1 forks, nor an L1 spindle on H1 forks.
Posted: Thu Jul 02, 2015 4:45 pm
by Tricky
thats fantastic, thank you very much. :smt023
