Clutch Cable Adjuster
Posted: Fri May 17, 2013 4:56 pm
by kai22
Hi all,
A while ago, I removed the radiator from my bike (it was my run around, now it's a project...) and to do so I removed the clutch cable as it ran through an eyelet type thing on the rad. Unfortunately I had to knock the project on the head for some time due to finances. Many moons have passed since and I need to move the bike due to a shed break in - the bike got left behind ONLY because it's stuck in gear with no clutch cable. Anyhoo, somewhere along the line I've lost the adjustment bolt that fits in the clutch lever. I asked a parts website if they had the bolt I needed (zxr 400 L model 91 - 92) and all I got in return was a link to this page -
http://www.wemoto.com/parts/lever_cable_adjuster
So far, I haven't been able to find which one I need.... could anyone point me in the right direction please?
Many thanks,
Kai22
Re: Clutch Cable Adjuster
Posted: Fri May 17, 2013 7:30 pm
by bendog66
You don't need to attach the clutch cable to get it into neutral
Posted: Fri May 17, 2013 7:55 pm
by kai22
bendog66 wrote:You don't need to attach the clutch cable to get it into neutral
So.... yeah, you were right there. Well since that side of things is sorted, any ideas on which bolt I should go for?
Thanks for pointing out the obvious to me lol, as you can see I tend to lack a little common sense at times :smt003
Cheers,
Kai22
