pinging
Posted: Mon Dec 29, 2008 2:45 pm
by fzalfa
hi
i have experimented pinging at about 15-15500 rpm, is it normal ? too high rev ?
Laurent
Re: pinging
Posted: Mon Dec 29, 2008 3:02 pm
by zimm
what do you mean by "pinging" ? and what ignition are you running thats allowing the bike to rev to over 15,000rpm ?
H model rev counters over-read, stock ignition limits to 14,500rpm.. before my clock was calibrated it would show over 16,000 !
FWIW, my H1 runs to 15,500rpm with raised compression and loads more ignition advance than stock and doesnt "ping" at all.
Re: pinging
Posted: Mon Dec 29, 2008 3:11 pm
by jake
does running toad fuel with advanced ignition cause it to ping zimm?
by the way, you fancy comin up to oulton? trackday feb 17th, 45 quids mate
Re: pinging
Posted: Mon Dec 29, 2008 3:33 pm
by zimm
jake wrote:does running toad fuel with advanced ignition cause it to ping zimm?
probably would, but at what point ? who knows .. ive only run mine on super since doing the work on it.. and after lots of messing and dialling in more and more advance.. its not detonated or started "pinking/pinging"..
think my point was that he's probably twatting it off the 14.5k limiter, (and has an optimistic tacho) rather than pinking due to excessive revs.
jake wrote:by the way, you fancy comin up to oulton? trackday feb 17th, 45 quids mate
full day for £45 ? aye possibly.. have to see how im set closer to the time.. least i'll be closer now.. 4 hour drive instead of 6 ! w00t .. lol
who's it with ?
Re: pinging
Posted: Mon Dec 29, 2008 3:47 pm
by fzalfa
yesi mean ignition pinging
so, i think i have dirt in my carbs.... cause after it run on 3 cyl at idle, i had this last week, water in carbs tank.....may i check my fuel tank.. i re start it some minutes later and i run fine. last time i cannot go beyon 6000 rpm....i clean the carbs, full of water !!
Laurent
Re: pinging
Posted: Mon Dec 29, 2008 5:05 pm
by jake
i would deffo say there is your problem. It would be nice if they ran on water tho
Zimm, its with hottrax. you not in wales now then?
Re: pinging
Posted: Mon Dec 29, 2008 5:22 pm
by zimm
still in wales atm, i'll be in hereford by the end of Jan though. Not ideal, but a bit more accessible
Re: pinging
Posted: Wed Dec 31, 2008 10:48 am
by fzalfa
too bad....
in fact i was in reserve, no more fuel........must turn the switch
i must be the only guy who buy a brand new sparkplug when the engine won"t run correctly....and it was to esay to switch the fuel to res.....the bad habitude with experiment issue with two stroke engine....
Laurent
