Gear Change Problem
Posted: Wed Jul 16, 2008 12:33 am
				Hi, I have a problem with gear changes and would be grateful for some help.
The bike grinds changing gear up or down. I have tried adjusting the gear pedal change position without any luck.
Basically the bike will not go into first unless I roll it forward a bit but then it has problems going from 1st to 2nd.
If I roll the bike back a bit she goes into 2 through to 6 and back to neutral but will not go into first unless I roll forward again.
Whilst riding this can be terribly annoying. She is slightly over full on oil at the mo and the clutch cable is worn. But even turning out
the clutch adjustment screw all the way to provide the correct clutch operation of 2mm did not help this.
Is this a gearbox or clutch problem?
