swapping cams L to H and cam tops
Posted: Mon Jul 07, 2008 5:53 am
After 6 months of procrastinating, I just swapped my L cams for H and swapped the H model cam tops along with it as I buggered my L's ones (I could repair them at one of the local machining specialists, but figured I'd get some undamaged goods and as close to SP cams as I could afford). Used all the right lubes as the manual says. Started her up and she runs fine, sounds a little gruntier (as I expected); goes fine when I took it around the block...blah blah, have done about 5 kilometers so far on these things without revving past 9,000rpm (there doesn't seem to be a noticable powerband at 4k rpm; I think it moved to 2000 rpm, and there is slightly higer compression than I remembered; but that could be because I gaped the spark plugs, am running a mixture of old petrol with newer put lower octane petrol and I haven't ridden it in a while).
Now here's my dilemma: I just spoke with another fellow who says that I should have line bored the whole thing before assembly. I don't doubt his background (worked constructing heads for Chevrolet in the US) but his concern lies with bearing squish upon tightening the caps, thus miss-aligning the setup, destroying the bearings and overheating the head. Being that the 400's head hasn't any bearings, should I be concerned about line boring the head?
I'm a little concerned about there being different wear patterens on the cam support journals in the head; but that's all so far. If the Cam was warped I think the Mechanic I got to inspect the rig would have saw it. What's the lieklyhood of the cam not fitting properly, and what should I listen for and expect if it doesn't? Are any of these concerns worth worrying about?
the manual doesn't make note of line boring when swapping cams in the H model Top-End section (I don't see why it would either); but let me know your thoughts with regard to my brand-spanking-used cams.
