generator cover
Posted: Sun Nov 25, 2007 2:10 pm
by bleddynzxr400
hi guys before i take of the left hand side engine casing think its called the generator cover. will there be oil in there and should there be oil in there and if there is oil in there is something knackered
bledd
Re: generator cover
Posted: Sun Nov 25, 2007 2:21 pm
by zxr_oli
Yup, make sure you drain the oil first, and place the tray under while you unscrew it just incase ;)
Re: generator cover
Posted: Sun Nov 25, 2007 3:25 pm
by bleddynzxr400
so there is oil supposed to be in there ok cheers
bledd
Re: generator cover
Posted: Sun Nov 25, 2007 3:27 pm
yep its meant to be in there, as oli said make sure you put a drain tray underneath as you take it off, or you will get oil everywhere!
Re: generator cover
Posted: Sun Nov 25, 2007 4:35 pm
by bleddynzxr400
just to confirm guys this is the cover im on about in the pic
bledd
Re: generator cover
Posted: Sun Nov 25, 2007 4:37 pm
by rover220
thats a mudguard lol, me thinks youve posted wrong pic.
Re: generator cover
Posted: Sun Nov 25, 2007 4:38 pm
by zxr_oli
All i see is a wheel and a rad :smt017
Re: generator cover
by bleddynzxr400
sorry wrong pic above
bledd
Re: generator cover
Posted: Sun Nov 25, 2007 4:43 pm
by zxr_oli
Yup, that's it.
Re: generator cover
Posted: Sun Nov 25, 2007 5:00 pm
by bleddynzxr400
ok cheers wasnt sure if theres meant to be any oil in there cheers
bledd
Re: generator cover
Posted: Sat Dec 01, 2007 12:33 am
by Random
You guys sure because i'm sure there isnt suppose to be oil in there because if there was wouldn't the alternator coil winders short and blow up ?
Re: generator cover
Posted: Sat Dec 01, 2007 10:57 am
Random wrote:You guys sure because i'm sure there isnt suppose to be oil in there because if there was wouldn't the alternator coil winders short and blow up ?
Definately oil in there mate, the coil is a sealed unit.
