Zxr400 Valve clearances
Posted: Sat Sep 05, 2020 6:49 pm
Hi guys new to the forum.
Just doing a valve clearance check on my 1989 zxr400 that I’ve picked up recently. Had some very tight intake clearances.
But the issue I’m having is No2 Cylinder right side exhaust rocker guide will not slide across, it will move over 1-2mm then stop, all the rest have been fine to slide across with my little make shift tool. Anyone had this issue before?
Thanks in advance
Thanks in advance
