Are H pistons the same as L???
Posted: Sun Jan 03, 2016 3:22 am
by tosser
I believe the rings have the same part numbers.......but what about the pistons? Anyone?
Re: Are H pistons the same as L???
Posted: Sun Jan 03, 2016 10:46 am
by Miles
A standard L piston part number is 130011333
So check that against the H
As for base gasket a lot of racers run without it as it slightly increases compression. Don't know if you need to use a liquid gasket in its place though
