Do I need a base gasket??
Posted: Sun Jan 03, 2016 3:18 am
by tosser
Can I ditch the base gasket and simply use 3 bond instead?
Re: Do I need a base gasket??
Posted: Sat Feb 20, 2016 4:26 pm
by richyrd5
Yes you could...but wouldn't recommend it as the gasket will affect squish/compression so would be best to use the gasket if you can...why do you want to use just sealer??
