Valves Bouncing...?
Posted: Tue Apr 19, 2011 2:29 pm
				I finally got my L1 back together after having the head skimmed (to it's limit), snapping a head bolt and removing it, replacing the head gasket, oil and coolant change (new oil filter) and new plugs which is fantastic!
BUT.....
The engine starts and runs a little lumpy (but some carb balancing should sort that out) and when I give it some revs I can hear a tapping sounds get louder as the revs go up. Is this the valves bouncing off the pistons?
The head has been skimmed right to the limit - actually clipped a valve.
Just wondered if this is a major problem or could be sorted with some timing alteration...?
			BUT.....
