				Cam chain tensoiners
				Posted: Mon Feb 07, 2011 7:01 pm
				by mikeyjp1980
				Hi All I am currently trying to solve a few issues with my bike I think possibly its the starter motor/alternator but The AA man seems to think its A Bent valve or B Cam chain tensioner. Long story short Riding home bike cut out whilst doing 30mph and would not start it made no noise just cut out. Made a funny noise coming from the starter motor/alternator and had no font head light on when I treid to restart.Now it had made this noise before when I used to start it before the battery died but seemed to do it less and less with a new one on. Left it a day and it started. So ive stripped it down oiled he starter and it started and then when I tried again it made the same noise but if you hit the start button quick over and over it starts ?? So im wondering if the cam chain tensioner is knackered  or a bent valve will the bike still start ? or was I being just flogged off by the AA ? Also how can I check the cam chain tensoiners as I have checked the manuel but cant seem to find it ?
				Re: Cam chain tensoiners
				Posted: Mon Feb 07, 2011 10:28 pm
				by Mori Man
				Certainly sounds like a starter motor fault thats drawing to much current - maybe commutator is making earth from wear, check the brushes - I have repaired in the past using washing machine ones filed to shape and using a hacksaw blade to redifine the pads that they make contact on.
Bent valve, engine will start to a fashion but ruff running - possibly plumes of smoke from can and unstable tickover.
Knackered tensioner , chain - the thing is going to sound like a biscuit tin half full of nails being shook about.
The tensioner is Auto but over time they can become sticky so no harm in resetting them, your concern would be if bike is approacking 30K miles or known to be regularly been thrashed to bits and a terrible noise ! You will find it on right hand side of bike the cover in front of clutch on the lower left side - clutch cable holder is also in same location - do not disturb unless you know what your doing or can follow the workshop manual instructions ! You will do more harm than good.
Tight valves make no noise but cause running problems - when was your last shim check done ?
MM!
				Posted: Tue Feb 08, 2011 4:43 pm
				by mikeyjp1980
				Ive owned the bike for almost a year since I passed my test. ive looked in the history and cant see when the valves were last shimmed. Ive got a new starter on order so im hoping to recive it in the next few days so im hoping to fit it at the weekend. the bike never did this untill the battery died just before xmas. I there any way to see if the valves need reshimming ?
				Posted: Tue Feb 08, 2011 11:45 pm
				by Mori Man
				You can do a compression test on the cylinders - this can help determine , load test that you see them do on car engines if you ever go to a tuners.
Best by far is to get in about them and measure the gaps - what mileage has the bike done ? Knowing the gaps are good gives you peace of mind to thrash it
MM!
				Posted: Wed Feb 09, 2011 12:26 am
				by Daniel.p
				i just had my camchain tensioner and blades changed and MM is right if it sound's like a bat out of hell rattling its a$$ off itll be the chain/tensioner also when you give the throttle a quick flick you should hear the chain grab suddendly and rattle very harsh but remember the clutch is very noisy when you pull off and it bites you should hear that rattle a tad
 hopefully that's helped just getting the ropes myself finding out the bloody hard way- all goes wrong then i learn
				Posted: Wed Feb 09, 2011 7:05 pm
				by mikeyjp1980
				Well just changed the starter motor over tonight. But the bike still wont turn over you hit the start button and you have a bit of a clanging noise then you hit the start button quick over and over and the bike starts to turn over ????? Hmm bit stuck for ideas now could it be the chain tensioner or is it the alternator ???
				Posted: Mon Apr 09, 2012 9:50 am
				by kronic2011
				could this be the starter solonoid?
