				Oil leak from the front of the engine....?
				Posted: Tue Jun 29, 2010 5:36 pm
				by bsrhkr
				hi, i just noticed that theres some oil leak at the front of the engine. i have no idea where its coming from, i put too much oil in the other day and didnt notice that it was too much until ike 5 days after so i had to drain some off. i dont knw if that was the cos of it or something else? heres a pic of it.
				Re: Oil leak from the front of the engine....?
				Posted: Tue Jun 29, 2010 7:44 pm
				by Miles
				Looks like the rubber rocker cover gasket is gone, you could try some liquid gasket on top see if that seals it or get on the phone to Cradley's
				Posted: Tue Jun 29, 2010 10:27 pm
				by bsrhkr
				Miles wrote:Looks like the rubber rocker cover gasket is gone, you could try some liquid gasket on top see if that seals it or get on the phone to Cradley's
 oh no
  lol
 how hard is it to get it replaced? or put that  liquid gasket on?
				Posted: Wed Jun 30, 2010 12:15 am
				by Miles
				Not that difficult, personally I would just replace the rocker cover gasket. Cradley's Kwak is your place for that. No idea of a price.
easy enough job to do yourself. Need to lift the tank and airbox. Then just remove the 4 rocker cover retaining bolts (Carefull not to loose the rubber gromets). Lift the old gasket and seat the new one, easy
Have a good look at the old gasket first to make sure it's not something else though before you buy something you don't need
Good luck
				Posted: Wed Jun 30, 2010 10:50 am
				by bsrhkr
				Miles wrote:Not that difficult, personally I would just replace the rocker cover gasket. Cradley's Kwak is your place for that. No idea of a price.
Good luck
sounds easy to me
  and yea i will check it b4 buyin anything then see how it looks. thanks for ur help
				Posted: Wed Jun 30, 2010 11:48 am
				What miles says....................
However can I ask how did you manage to top up your oil and not notice that you had over filled it ?
				Posted: Wed Jun 30, 2010 4:12 pm
				by bsrhkr
				cargo wrote:What miles says....................
good question!
umm well basicaly, when i bought the bike, it was on the side stand, looking at the little window there was no oil so i thought well i gotta put some oil in (while it was on the side stand)!
   i knw its stupid but yea thats what happened until my brother went on the bike and i looked at the window and the oil was covering the whole window
 so i had to drain abit out. i didnt ride the bike i just started it for like 5 mins for that 5 days cos i didnt have my licence back then. but learn from mistakes thats what they all say isnt it
				Posted: Fri Jul 30, 2010 8:52 pm
				by alanh
				got the same issue with mine (not overfill, rocker cover gasket) cover comnes off with 4 bolts, make sure you dry out the 2 mating surfaces, slap the new gasket on and job done. If you like you could put a very small bead of silicone on the face of the cover and head but shouldnt be necessary and could damage the gasket if you ever remove the cover again (which you will need to for shims etc.) meaning you'll need to replace it again, they can usually be re-used if not
