Coolant
Posted: Fri Jul 31, 2009 11:30 am
by CaNsA
Which is the ZXRWorld preferred brand?
Re: Coolant
Posted: Fri Jul 31, 2009 11:55 am
by Davw
Distilled water
Re: Coolant
Posted: Fri Jul 31, 2009 12:02 pm
Davw wrote:Distilled water
Damn you beat me to it
Re: Coolant
Posted: Fri Jul 31, 2009 12:09 pm
by CaNsA
I would but the bikes running rich, and very hot so need summin a bit stronger that water
Re: Coolant
Posted: Fri Jul 31, 2009 12:18 pm
by Wabby
Silkolene in mine atm.
Re: Coolant
Posted: Fri Jul 31, 2009 2:06 pm
by reds
says 50/50 mix in the manual as the water can damage aluminum parts ?
i use the stuff from wilko - cause its cheap ! its either 2 or 3 quid for a litre
Re: Coolant
Posted: Fri Jul 31, 2009 10:27 pm
by Davw
CaNsA wrote:I would but the bikes running rich, and very hot so need summin a bit stronger that water
I doubt if the coolant will make much difference. In reality the whole collant thing is just a simple heat transfer - from engine to collant and from coolant to air (at the radiator). If the bike is overheating there is a real problem that needs to be sorted before damage. Have you flushed out the radiator/ checked for blockages/ is the thermostatic valve working properly (if not it could be holding the temperature high) etc etc
Re: Coolant
Posted: Sat Aug 01, 2009 7:45 am
by Wabby
If running very hot it could also be headgasket failure!
Re: Coolant
Posted: Sat Aug 01, 2009 10:55 am
by CaNsA
Cheers for the info guys.
Im 98% sure it aint a blown HG, i have a power filter and an after market can on there and the bike aint hasnt had any jet work done yet. I keep promising the bike that ill take it up there but stuff always comes up.
