Page 2 of 3
Re: coolant coming out overflow update 26/10/13 HG time ??
Posted: Sun Oct 27, 2013 2:41 pm
by spudboy6
Cheers ross46 , your the chap selling the gaskets aren't you ? Can I get a pulse cover gasket of you ?
Right started getting on with it earlier an took the pulse cover off to see how the chain is looking and my god wish I didn't
Chain is on max adjustment , so chain needed (tensioner can be reset ? )
And found a half moon almost like a staple in there
What's that ? Pic to come
Posted: Sun Oct 27, 2013 2:44 pm
by spudboy6
Posted: Sun Oct 27, 2013 3:15 pm
by ross46
That doesn't look like the tensioner, I think that is an actual staple
and send me your address and send the money to
ross_46@hotmail.co.uk and I'll get it sent tomorrow for you
Posted: Sun Oct 27, 2013 3:39 pm
by spudboy6
Cheers pal how much do I need to send you ?
Yea it looks like a staple to me , I recall a thread a few pages back with the part that was a half moon sat in the case but his was much thicker.
How would a staple get in there
Posted: Sun Oct 27, 2013 3:58 pm
by ross46
The pickup The oil is magnetic, could have picked it up somehow? And £4.50 for the gasket
Posted: Sun Oct 27, 2013 4:05 pm
by spudboy6
Cheers ross46 money is sent
Will try and have the engine out tomorrow and get it stripped
To get the forum discount at cradley do you have to ring them or can you get it online ?
Posted: Sun Oct 27, 2013 4:46 pm
Am I the only one who has noticed that the tenioner is fully maxed out?
Posted: Sun Oct 27, 2013 4:55 pm
by spudboy6
Few posts up I've stated its having a new chain and I asked if the tensioner can be reset but didn't get an answer
Posted: Sun Oct 27, 2013 4:58 pm
by CaNsA
spudboy6 wrote:Few posts up I've stated its having a new chain and I asked if the tensioner can be reset but didn't get an answer
Yes it can. you have to compress it and get a paper clip or that staple you found and shove it in the hole before refitting the CCT.
Once fitted pull the pin / staple out and the CCT snaps into place.
Posted: Sun Oct 27, 2013 5:17 pm
by spudboy6
Okay thanks for that I wasn't sure how it was done as I've read about some being a ratchet design or is that older ones ?
I'll get on with it over the next few days when I get to the tensioner does it need removing from the case at all to compress it or should I leave the bolts alone on the outside ?
I'm sure when I get on with it will all make sense
Posted: Sun Oct 27, 2013 5:41 pm
CaNsA wrote:spudboy6 wrote:Few posts up I've stated its having a new chain and I asked if the tensioner can be reset but didn't get an answer
ERRRRRRRRRR ~NO
the tensioner in the pic is the upgraded one...........tension is applied after fitting the body when the springs and bolt are replaced
the staple is interesting....................HTF did it get in there.......
Am I the only one who has noticed the metal filings on the left pick up bolt ??
Posted: Sun Oct 27, 2013 6:20 pm
by spudboy6
Yea I've noticed the filings very un-nerving what I came across when I took the case off , will just have to remove and inspect parts as I go along and see what I find
Posted: Mon Oct 28, 2013 7:29 am
I noticed the filings too....
Posted: Mon Oct 28, 2013 2:42 pm
by ross46
Seem to be fairly common in pictures that ive seen, probably not seen in race engines or ones that are looked after, first time I took pulse cover off they were there, but since I haven't seen them, regular oil changes probably helps, never many filings in the filter which I cut and check every oil change. They could just be getting stuck there, thats the idea behind magnetic sump bolts. And spudboy6 I got your mobey but need your address to send the gasket.
Posted: Fri Nov 01, 2013 8:04 pm
by spudboy6
