Oil Cooler Removal
Posted: Mon Dec 03, 2012 4:27 pm
by raceyunky
If i take off the oil cooler should i link the pipes together or blank off on the engine?
Common sense is telling me to keep them connected without the cooler in the circuit, if so does anyone make such a connector?
Re: Oil Cooler Removal
Posted: Thu Dec 20, 2012 11:01 pm
by thomp1983
you can remove and bypass the oil cooler using the stock lines, iirc the longer one just needs bending round to fit but it's fairly obvious once you get down there and look
chris
Posted: Fri Dec 21, 2012 7:46 pm
pretty sure you can just blank them off too.
Posted: Sun Dec 23, 2012 9:34 pm
by Ewetea
I decided to take the safe option to ensure that oil flowed without any restrictions. I used a piece of 10mm central heating pipe with elbows and a couple of scrap pieces of brass. Oh - and a couple of gaskets cut out of a Cornflakes box.
Posted: Thu Dec 27, 2012 10:44 am
by R P Corse
thats pretty cool that!
though im still unsure on the benefits of losing the oil cooler - apart from losing the weight
MotoGP bikes have oil coolers on
Posted: Fri Dec 28, 2012 10:07 am
by banner001
someone needs to stick a couple of thermocouples around their bike, sling it round a track with/without oil cooler, then around town with/without.
Posted: Fri Dec 28, 2012 10:28 pm
by rccaulfield
BigB wrote:thats pretty cool that!
In fairness the gp bikes have huuge fire breathing engines in em and cooling is an art! Yea weight loss thats it!- Its a racing mod imo!
Posted: Sat Dec 29, 2012 11:08 pm
by R P Corse
rccaulfield wrote:BigB wrote:thats pretty cool that!
lol oh i agree bout the GP engines are fire breathers lol
i mean i've seen lots of people have pros and cons about removing the cooler, as much as i'd like to try it out, im scared as to how hot the bike would be
Posted: Mon Dec 31, 2012 1:53 pm
by alanh
removed my oil cooler on my racebike, just made a blanking plate up that covers both holes and fits onto all 4 boltholes. If engine cooks itsself i will report back and let you know
Posted: Thu Mar 28, 2013 3:20 pm
by AFM327
My bike still has the oil cooler on it but the new build will see it removed. It runs at the right temp when it's almost 100 degrees F outside without any tape on the radiator. That would be just over 37 C for the metric crowd.
Mine doesn't run on the street, only the track.
Posted: Tue Aug 12, 2014 5:18 pm
by stevi5
Hi Guys removing the oil cooler is perfectly fine and you can simply blank the cooler outlet and inlet feeds, no need to have a bypass system like the one in the photo as in practise only some of the oil from the pump goes through the cooler anyway. I have blanked mine but I have fitted a cooler from a ZX6r which fits where the oil filter is and is water cooled.
Hope this helps steve
Posted: Thu Aug 14, 2014 10:20 am
by titi bzh
Hi Stevi5
Do you have a picture of the Zx6r system?
Regards
Thierry
Posted: Tue Sep 02, 2014 2:43 pm
by stevi5
Yep but not sure how to post it on here, if you let me have an e-mail address I will mail them to you direct.
regards stevi
Posted: Sat Oct 18, 2014 6:52 pm
by AFM327
Blanked off my oil cooler as I found a cracked line while prepping my bike a few days before my last race. Still had to tape the radiator to keep it in the right temp range. Cut them with an angle grinder, used the lines as a template for drilling the holes, no issues, no leaks and I got a third after not racing for over a year.
Posted: Wed Aug 26, 2015 5:03 pm
by titi bzh
Hello.
Do you think that after removal oil cooler , the seal valves can be damaged (oil too hot) ?
Titi
