zxr400 L3 wont run on choke, overfueling?
Posted: Wed Feb 01, 2017 12:21 pm
Hi,
recently bought a L3 model (Saturday) and noticed a problem straight away.
When I first went to see it no issues this was a month ago.
Now Saturday when I brought it home I took it for a little spin, noticed it wouldn't start on choke at all would tick over, cut out then click and nothing. So turned choke off start on button no problems Revs as it should idles fine no issues. (little strange but thought hey ho old bike)
However it also have a Hot starting problem. When I pulled up and refueld tried to re start the bike and it wouldn't start on the bottom, had to use some throttle. ITs been the same for the last 3 days have to use throttle when its already warm.
Bikes runs fine got the usual flat spot at the bottom end of the Revs and its great higher up.
I think it maybe a problem with over fueling slightly? so either Carbs need cleaning and balancing, or the O Rings or needle need replacing.
Has anyone had any experience of this at all?
