Winter bike work
Posted: Sat Dec 14, 2013 8:42 pm
Ok whats everyone doing over the winter months to your bike?
here's my list:
70cc scooter: replace 19mm racing carb with 17.5mm and get it fuelling right, replace pod filter with stock airbox.
zxr400 l3 track bike: setup the dynojet needles, adjust mains if necessary, sand down fuel tank/rear single seat unit/front wheel fender, remove alternator system and adjust wiring to suit, remove fuel pump relay and associated wiring, look for cheap lithium battery, lap in the valves and fit new head gasket (no need, all cylinders 150psi), source new 4-pot 600cc brakes and fit maybe along with new disks.
fzr 1000: drop oil now engine is starting to be run in, check compression (for my records), sort out lumpy idle, design a subframe for the R6 tail unit.
zxr400 l4 commuter: needs a major service, now at 47,000 miles and still going strong, needs the valves lapping and a new head gasket, needs compression checking before/after head work, needs the cooling system looking at, ill take a look at the water pump to make sure its not damaged, the radiator really needs looking at - gonna try to clean it but i think will involve removing a load of fins...although i cant make it worse than the solid mass that it currently is...i really need a replacement. im gonna take the headstock and suspension linkages and give everything a good degrease/re-grease, replacing damaged/worn bearings as necessary.
other things: i need to get a dummy tank and make a stand to hold it and my carb balancers to make it an easier job, a bit of aluminium rod and a bird stand-type base will be fine. overhaul air compressor if i have the time/money.
here's my list:
