Plugs and leads
				stonemonkey
 - My Bike: Zxr400 L2
Plugs and leads
Anyone if there are any aftermarket ht leads? Mine have split and separate from the plug end..
				thomp1983
 - My Bike: zxr 400 l3
Re: Plugs and leads
you usually have to buy ht lead wire and the ends on your old leads screw off then onto the new length of wire, or it'd be a great time to fit stick coils and do away with ht leads completely
chris
						chris
				stonemonkey
Re: Plugs and leads
Hmm I will probably go for the coil stick mod if a well priced loom and set of coils come up.
				thomp1983
Re: Plugs and leads
http://www.ebay.co.uk/itm/HONDA-CBR-900 ... 3a6bba2382
there cheaper than the set ive got and he'd probably take £30
chris
chris
				stonemonkey
Re: Plugs and leads
thanks, is the length and diameter a direct fit for the plug hole onto the spark plug? Are thay a tried and tested swap over for an L2 ?
cheers
						cheers
				thomp1983
Re: Plugs and leads
after a bit of digging around google shows there the same part number as the cbr 600 ones i fitted to my bike so yes they should fit fine
chris
						chris
Re: Plugs and leads
That's friggin cheap for that set-up , would need to pay almost that just for the used loom ! Same as I have in my H2
You do get Sunfire leads & caps which also have bonded earth straps on them - got a set in a box somewhere and as said you can just replace the standard HT with any modern kit you can find, copper or silicone core, car or bike - 7mm is ideal but you can squeeze 8mm in but the sealing gromits on the coils wont fit.
MM!
MM!
				stonemonkey
Re: Plugs and leads
Put an offer for £28.50 in and it got accepted so they should be on their way
Re: Plugs and leads
stonemonkey wrote:Put an offer for £28.50 in and it got accepted so they should be on their way
Haven't done many miles with mine and it's got to be over 18months since doing and no problems or regrets
Got a set of sticks on the shelf for one of the next builds - just need to source the loom bit.
MM!
Re: Plugs and leads
You got a bargain - check these:
http://www.ebay.co.uk/itm/CBR1000RR6-4- ... 3a66e18ee1
http://www.ebay.co.uk/itm/HONDA-CBR600R ... 3a66e14df6
Bit more sensible:
http://www.ebay.co.uk/itm/HONDA-CBR-600 ... 415e4c2241
Bit more sensible:
				stonemonkey
Re: Plugs and leads
Some big variations in price there! Engine won't be going back in for a few months as it need a jolly good clean and paint. Cheers for the help.
				thomp1983
Re: Plugs and leads
i did have to dig around to find them at that price, i think i paid about £50 for mine, with the exception of my fireblade calipers there probably the best upgrade ive done they've helped make the bike alot more rideable at low revs (below 6k)
chris
						chris
