interchangeable between years?
Posted: Sun Jul 17, 2011 11:27 am
by R P Corse
i know H models are all the same ... but is there any interchangeable parts between the H's and L's?
i should really do my research lol but im a bit puzzled where to start, looking at new discs - are they the same fit on ALL models? same with exhaust systems - downpipes all the same? does anyone have a list of parts that can be changed etc..
obviously i want parts that dont have to be cut and welded to fit, im just interested in straight swaps.
thanks. B
Re: interchangeable between years?
Posted: Sun Jul 17, 2011 5:41 pm
Exhausts do swap but discs dont or at least not without some alterations
Loads of parts to swap...........even engines
Posted: Sun Jul 17, 2011 7:44 pm
by R P Corse
brilliant, thanks mate, what about forks?
Posted: Sun Jul 17, 2011 7:49 pm
if you change the wheel and calipers the forks will swap too I beieve................never tried it myself...............others will know for sure.
Posted: Mon Jul 18, 2011 2:42 am
by Mori Man
Forks - nope , even if you swap everything you need the pin changed on the tripples for a H and then 50mm extensions onto the L forks as they are too short.
Ls are lower - mmmmmmmmm , L = Lower :smt005
They are also longer - mmmmmmmmm , L = Longer
Should have been a LL :smt017
Just seen a SP400 class SP that was raced profesionally and has a modified H1 arm on it to give higher corner speed with a shorter wheel base :smt004
MM!
Posted: Mon Jul 18, 2011 10:10 am
I knew MM would be along soon enough with some correct information.................
Nice SP...............
Posted: Mon Jul 18, 2011 2:03 pm
by R P Corse
much appreciate the info guys!
i guess i'll have to get the front end repaired then, im sure one of the legs are bent, it hates cornering in the wet turning right but left is fine - tips in a lot quicker on the right!
is it worth sending the forks off to a company to get them straightened and set up for me or would it be cheaper to get a set or forks from another bike like the 636 etc..
Posted: Mon Jul 18, 2011 2:25 pm
by Mori Man
If you get 636 forks you could hone out the bottom clamp - you need to take out R0.5 and they will slip in - need top hats made for your axle if you want to keep the 4's wheel and speedo drive plus a couple of wheel spacers.
Fit the complete 636 front end and your left with no speedo drive.
MM!
Posted: Mon Jul 18, 2011 5:24 pm
by R P Corse
nice one mate! appreciate the help, im used to working on Aprilia's n 2 strokes! sorry for all the questions!
final question about forks spoke to a few companies earlier asking about rebuilding my forks, do the stantions from L models fit the H's (not the slide - the bit that holds the calipers!) as they are what need replacing.
