50mm exhaust slip on??
Posted: Fri May 06, 2011 1:31 pm
by wildkid
Looking for a exhaust like an akrapovic or some sort of perfomance can with a 50mm inlet ? would it fit onto the original bracket as well with the BEET copy pipes?
Re: 50mm exhaust slip on??
Posted: Wed May 18, 2011 7:13 am
by Mori Man
Check to make sure it is 50mm , I only know of one maker here that uses that size WR's.
BEET is 50.8mm along with a heap of other makers.
Next common sizes are 54mm (Yoshimura, Akra's) and 60.5mm everything else (some weird sizes in between) , you can get reducers to make for smaller link pipes which I have used to fit the small MotoGP K-Factory can and a large Stricker carbon in the past.
MM!
