Problem
Posted: Tue Apr 26, 2011 9:55 am
by wildkid
When i let my bike idle, my right indicator is fine, but my left flashes a lot slower and sometimes even stops flashing and is just a constant light?
also when i try starting my bike from hot, it sounds as if the battery is dead/ struggling but as soon as its cold, it just fires back up straight away no problems?
Re: Problem
Posted: Tue Apr 26, 2011 10:29 am
by Daniel.p
The problem starting is kind of normal as most of us have the hot start issue theres a thread dedicated to it the indicator is mayby a bad connection or your relay could be naff
Re: Problem
Posted: Tue Apr 26, 2011 6:48 pm
Indicator sounds like its a dodgy contact somewhere. Check the bullet connectors to make sure thye are pressed together fully.
Starting issue does sound like its the hot starting problems that ZXRs are famous for.
viewtopic.php?f=166&t=3391
