h1 update
Posted: Thu Aug 05, 2010 7:19 pm
by Tom mccrea
well the front brakes are now pretty much sorted out, need to order some seals but they are working ok. the back brakes are binding quite a lot and the bleed nipple is broken off so will have to be drilled out, great! On the bright side its progress i suppose.?
Re: h1 update
Posted: Thu Aug 05, 2010 10:09 pm
by reds
i had the same problem with mine snapping on the rear, but managed to fit it and bleed it fine with the other nipple, didnt need both of them - one was enough to get the fluid into the whole caliper
