wont rev.
hipringle
wont rev.
Post by hipringle »
Well, I got the carbs back on this morning, seems to be running on 4 cylinders now, (cylinders 1 & 4 take a while to heat the exhaust unlike 3 & 4 tho). anyway, it revs ok & pretty clean up to about 8 thou then thats it, it,ll strain & struggle to get any more when blipping the throttle.
Have I not cleaned the carbs well enough or could it be plugs (standing three yrs) or could it be the vfr750 fuel pump thats been retro fitted!
Theres also a big hole in the manifold & the silencer has been dropped on literally. could that poss stop it revving out. Is it totally shagged, am I flogging a dead horse, does my boxer fart more than the missus,
answers on a postcard please.......
think you are flogging a dead horse mate, i'll give you what you paid for it :smt003
the hole in the manifold ain't gonna help mate.
hipringle
Post by hipringle »
Cheers mate, Jmez is selling me his old manifold & downpipes at the weekend when he,s back so that should take one thing outa the equation.
ps, leather on its way mate, fanarr fanarr!!
hipringle
Post by hipringle »
cant really do much to improve its running till I get the good set of downpipes so I think I,ll start on the panels when I get a spare few hours.
I,ve also got the calipers to free off sometime.
sure its not restricted?
sounds like its not getting enough air, check airfilter.also check the chokes not stuck on aswell
hipringle
Post by hipringle »
Hmmmm, choke defo not stuck on, air filter is just a bit of foam right?, its not overly dirty.
hipringle
Post by hipringle »
Before I whip the carbs off again, I forgot to mention that sometimes the rev counter doesnt work at all. Its on zero then all of a sudden it,ll work. Could this be related to the bike not revving (deff readis right when its working). This just happens occasionally.
could well be an electrical gremlin in there, might be something to do with the cdi??
I think, that could be a low battery. I guy on here a few months ago had problems with his rev counter not working, and was down to the battery, im sure.
hipringle
Post by hipringle »
Thanks, I hope its battery related I had to jump start off me cage as I wore the new batt down trying to get it started in the first place!
hipringle
Post by hipringle »
Thanks RobB, I,d read the first one but not the second.
I,ll put a meter over it when its running,
Ta.
hipringle
Post by hipringle »
Grrr, bit annoying now. had the carbs back off, cleaned & put them back on again, its made no difference. All exhausts get hot especially the middle two but it still wont rev past 8 thou & its rough sounding up to there. Getting a spark on all cylinders & petrol doesnt seem a problem. I now think poss there might be a valve clearence problem or maybe coil breaking down or the missus putting a spell on me. I,ve a compression tester but it dont go down to the tiny size our plugs are. Trying to source an 10mm adapter locally so I can get it checked today. Theres an engine on ebay which also finishes today, I may have a bid on that if its not too dear near the end. Bloomin bikes eh!!, damm & blast.
rev counters fine for now, I cleaned up the contacts, wiggled & prodded etc etc. giving plenty of volts too across the battery.
feck, its over a hundred quid now so thats me out of the bidding for the engine.
Sounds like it might be the coils if the middle two arent getting as warm as the outer two. Check the little spade clips that connect tot eh coils arent corroded, or that the leads arent breaking down. I had this problem where one cylinder wouldnt fire up on my XJR400, i went a good year and a half thing it was valve guide seal just to find one day there was a fat blue spark jumping from the HT lead to the frame. A year and a fucking half of starting problems, if i knew it was as simple as that id have sorted it right away! Of which i did in due course once i knew what the problem was :smt001
hipringle
Post by hipringle »
RobB wrote:Sounds like it might be the coils if the middle two arent getting as warm as the outer two. Check the little spade clips that connect tot eh coils arent corroded, or that the leads arent breaking down. I had this problem where one cylinder wouldnt fire up on my XJR400, i went a good year and a half thing it was valve guide seal just to find one day there was a fat blue spark jumping from the HT lead to the frame. A year and a fucking half of starting problems, if i knew it was as simple as that id have sorted it right away! Of which i did in due course once i knew what the problem was :smt001
Lol, sorry mate but thats funny.
Good call tho, I,ve asked jmez fr his coils & leads off the bike he,s breaking but at the min I,ll have a root around that area,
cheers.
If I cant find anything obvious at the mo, I,ll run the engine, rev it & pull the leads off one by one with a spare plug in the end. That might show up a dodgy or weak spark.
