Tearing Down the Puig Tri-Caster Stand: Millimeter-Level Rigidity Exposes the Weaknesses of Ordinary Workshop Stands
Webike Japan
My Bike: Kawasaki Z900RS
Post by Webike Japan »
Listen up, fellow grease monkeys. When this Puig rear paddock stand hit my workbench, there was no way I was just throwing it together. As a maniac obsessed with structural integrity, I started tearing down the tri-caster mechanism the second it arrived to compare it against the unforgivable weaknesses of ordinary workshop stands. The engineering here is absolutely insane.
Ordinary workshop stands twist like wet noodles under a liter-bike dumping massive heat soak, but this Puig rig is bulletproof. The millimeter-level precision on the heavy-duty tubular welds translates to zero torsional deflection. I mic'd the inner bearings on the 3-caster setup, and the tolerances are tighter than top-end engine internals. It completely eradicates that terrifying lateral drift you get when wrenching on a fully loaded chassis sideways in a cramped garage.
The adjustable dual-hook system dials in flawlessly between 19.5 cm and 34.5 cm without a microscopic hint of slop. Lock the caster brakes, and the chassis feels anchored to bedrock, totally unaffected by the structural thermal drift radiating from a blistering exhaust.
I’ve got my swingarm spools completely dialed in, but the multi-directional physics of these casters on epoxy under severe thermal loads still fascinate me. So, here’s my question for the hardcore track veterans: When you’re tearing down the rear end and the chassis is still dumping intense heat soak, how do you guys perfectly dial in the caster tracking to prevent micro-creep?
https://japan.webike.net/products/26638 ... ign=46192
