Strange noise from front wheel
- Full Licence rider
Hi all i went out last night and at low speeds my front wheel is makin a catchin sound its abit wierd, i never noticed it before but now its all i can hear at low speeds. im not sure if it has anything to do with the stationry drop the other day but it didn't hit the ground hard the only thing broke was the mirror not a scratch elsewhere. anyway i was wondering if anybody knew what could cause this problem, i hope not a bent disc althoe it looks ok.
Could be your front wheel bearings. Would be a good idea to get the front wheel in the air and give it a spin, might be able to loacate the where abouts of the noise then. Might even be the pads on the disk, not that it might be bent but the brake pad plate (shiny plate on top of the caliper) could have come loose and lets the pads rattle around a bit.
yea, it sort of makes the sound of your old pushbike when it has a buckled back tire at 1 particular part its catchin, dont know what it is thoe. i aint got no tools to get the front up, ill have to sort it thoe.
- deviant
- My Bike: ZXR400 L3
if you can find a mate to help you can lean it over onto the sidestand and the rear wheel, with the front wheel in the air. one of you can hold it there while the other checks the bearings.
if you find something wrong of course then you will need a paddock stand or similar, unless you have a very patient mate!
- Jamz
- My Bike: Kawasaki ZX9-R C2
- deviant
but you'll worry about it anyway, even if you are imagining it!
lol tell me about it, iv got visions about doin a weely and just seeing the front wheel rolling alont the floor while im on the back wheel.
Well i aint got much experience at this but ill give it a go, iv got a paddock comin at the end of the month.
is it expensive to put right if the wheel bearings have gone.
tomzxr400
there £4 each at http://shop.wemoto.com/index.dyn there quite cheep for most things and fast delivery
- Little Loris
- My Bike: 2008 Yamaha R6
- Jamz
Ok folks iv had a development the noise goes when i pull the front brake thank god, so this means it aint a warped disk or the bearings so thats cool but its like a rattlin sound now somethin is loose i think.
oh an cheers for that website tomzxr because they cell mirrors singular even thoe they ar 25 notes no matter i dont think ill get one cos most people will brake the left mirror anyway.
think i've got the wheel bearings in stock? but i can't be blamed for goods lost in the post
