I have an L1 which is now 18years old with 35K miles on the clock. So I decided that it was time for a major overhaul. I started with the rear suspension which appeared in reasonable condition, and had passed the MoT. But when it was finally dismantled (refer to “Having problems? – L1 swinging armâ€) it revealed shot bearings and worn surfaces. Fortunately I know someone in the trade who sourced parts, together with new chain and sprockets, braided steel hoses, brembo pads, and a specially commissioned rear shok by Nitron, which looks as though it has been sculpted from an aluminium billet and then anodised (well it was £285….+ VAT).
The next item was the engine. I wanted to change the cam chain, but was mildly disturbed by reports of lumps that needed grinding off castings to facilitate removal and replacement, and chain guides dropping or jamming. I also wanted the bores and pistons checked, but was not thrilled with the prospect of replacing the barrel over all four pistons and squeezing rings to engage the bores. I was also interested in some mild tuning, so I looked for recommendations on ZXR world, and found DynoPro Racing at Chester. I sent an e-mail detailing the work I wanted done: gas-flowed head; new cam chain; shim the cams; check bores; new plugs and oil filter; cure oil leak; change water pump and thermostat. I received a reply within a couple of hours, with prices which I thought were reasonable. So I took the engine to them, and met Chris Nield, who is very enthusiastic, knowledgeable and practical. He told me that the bores would be OK, but recommended new piston rings. He also recommended that the bottom end should be checked. Since most of the engine would be stripped, the extra cost and work involved would be worth it. I’m glad I did, because some of the shells had started to pick up and others were showing signs of wear which would have rapidly worsened.
When I collected the engine I was given the old shells and rings as proof of work. Chris didn’t consider it necessary to replace either water pump or thermostat, and confirmed that the clutch plates were acceptable. I was also given advice on running-in the new parts, and even bedding in the gaskets. The gas flowing of the ports was superb. Chris mainly works with race bikes, so he is familiar with the requirements. I was very impressed and pleased with a professional job, and think I had value for money.
Do I hear you cry – “How much?â€
Remember – this is quality work.
Gas flowing the head = £180. It isn’t a case of using a reamer to open the ports because they are kidney-shaped. There are eight inlet and exhaust ports, each of which splits into two, so there is a great deal of fine hand fettling required. Also, it’s not a case of carving out lumps of alloy. The expert knows where and how to shape. So that price is a bargain.
Strip, inspect and rebuild top end (including shimming of valves) = £200
New cam chain = £27
New valve stem seals = £65
Piston rings = £102
Strip, inspect and rebuild bottom end (including checking the gearbox) £150
New shells = £70
You might think that was a lot of money, but look again at the parts alone and check the prices. I now have a new engine which will give me a lot of riding pleasure. Oh, and I intend to spend more money with Chris. Once the bike is rebuilt I will take it to him so that he can run it in and set up the carbs on the rolling road. Chris is that versatile that he can tune them for low, mid-range or top-end power as I prefer. I have seen too many topics posted on ZXR world complaining of “won’t start when hot/coldâ€, “no mid-range powerâ€, “splutters at top end†etc which are very likely due to carb problems.
So – how did I pay for all this? I saved. 50quid a week for six months generated a significant pot of money.
One more thing – Chris works a 7day week, so he is busy. Please don’t waste his time, and be prepared to wait. My engine sat on the shelf for two weeks before he could start work on it, and then it required two more to complete.
But it was worth it.
DynoPro Racing recommendation
Ewetea
- My Bike: ZXR400L5
Ewetea
- My Bike: ZXR400L5
Re: DynoPro Racing recommendation
Update: I put the engine back in the bike, together with replacement radiator and oil cooler. After 19 years of crud being thrown at them from the front wheel, a third of the surface area was blocked. It wouldn’t soak off in water and a jet washer just blasted the fins off. I removed the plugs and churned the motor over to fill the filter and cooler with oil. The bike was then taken to Chris at DynPro to run-in the engine and set up the carbs on the rolling road. He changed the oil after a couple of hours on the rolling road, and then installed dynojets and needles. By adjusting them, he achieved the best power output of 65BHP, which is the figure quoted by Kawasaki. BUT, manufacturers usually like to make their product sound good by quoting power at the crankshaft, and mine is at the rear wheel.
Whilst re-building the bike I started investigating “ram-air†boxes. It seems a brilliant idea – just use the forward motion of the bike to force air into the airbox to create a (free) turbo effect. HOWEVER, I discovered that in order to install such an airbox, the coils must be relocated, the top three tubes of the radiator must be removed, and it has no effect below 60mph. Chris also said that the carbs must be set up for top-end power, which means poor performance at less than half throttle. It really is a mod to be used for racers only. But he showed me a power curve for a ZXR400 which had the 440 conversion with Kent cams, and it was producing nearly 80BHP! Hmm. That may be next winter’s project.
- CaNsA
- My Bike: ZX6R F1
They are good guys up there, and they have helped me out and saved me a bit of cash in the process.
I have also seen that 444cc big bore zxr400 power chart and had a bit of a sex wee when it said "80.4bhp"
Good lads, I highly rate them
dynapro chart addded.
- lindaloo
- My Bike: ZXR 400
alot of money spent there to get it to 65bhp .... so mine is pretty damn good then...think mine will be thrown round a track next year
people say that before you die, your whole life flashes before your eyes... make sure its worth watching !!
zzr 600
zxr400
http://golfnutlady.spaces.live.com/photos/
zzr 600
zxr400
