So what should I do? Go for it as I will get used to it and enjoy the new power, or look for a really low mileage ZXR400 and get it done up exactly how I want it. Looking at around £4500 to spend?
I think there may be biast answers
The one in the picture above already has a lowering kit on it and I am just touching with the balls of my feet. With a seat shave I could almost get the heels to touch bar a centimetre or 2.Caz wrote:I assume that you can touch the ground?
sounds pretty much what I am like on my gixxer - i manage just fineCarneyUK wrote:The one in the picture above already has a lowering kit on it and I am just touching with the balls of my feet. With a seat shave I could almost get the heels to touch bar a centimetre or 2.Caz wrote:I assume that you can touch the ground?
Fully comp and crashbungs will be a definateMy main worry is the state of the roads like potholes at the traffic lights etc.
I think Jamz was referring to getting used to the powerstug wrote:The 10R will not necessarily be taller than the 6R.
The 06 R6 is taller than the 06 R1.
I know what you mean but I was just reffering to the seat heights.Caz wrote:I think Jamz was referring to getting used to the powerstug wrote:The 10R will not necessarily be taller than the 6R.
A very good point. I have also sat on a ZX10R and found it to be smaller than the 6R. So maybe I should get a ZX10Rstug wrote:I know what you mean but I was just reffering to the seat heights.Caz wrote:I think Jamz was referring to getting used to the powerstug wrote:The 10R will not necessarily be taller than the 6R.
If a bike feels too big for you it will not give you confidence, its not just down to engine size, your right hand controls the power.
My wife was thinking of getting an R6 after she is finished with the ZXR but after sitting on one she did not like the height of the seat and said she would be more comfortable with a lower bike. Although once you are moving it doesn't really matter how big the bike is ..there is a lot of the time where you have to move the bike around with your feet on the ground like while parking which she felt she would be paranoid about dropping it.
She has ridden my R1 and said it was really easy to get used to, with a bigger engine you do not need to try so hard to go quick which makes it easier to ride.
I hear u on that one mateCarneyUK wrote:
You do say the right hand controls the power ... agreed, all I would have to do is sneeze and I'd be off the back
