Headlights not working
- Dazzle
- My Bike: Kawasaki ZXR400 L3
Hi just trying to sort a few problems on my bike. The rear lights and indicators work fine as do the speedo and rev counter back lights, my problem is the headlight, when i turn the ignition on theres nothing even the pass switch doesn't do anything i've put a new relay on and checked all the fuses. Could it need a new switch gear? i've bypassed a wire where the relay goes and can get the main beam to work its just dipped beam. Thanks Daz
Re: Headlights not working
if you've put a new relay on i'd say the switch has gone, was it brand new from a dealer?
- Dazzle
Yes it was. i'll have another fiddle with the connectors and check for voltage at the switch failing that i'll try another switchgear. Thanks for your help!
- markzxr400l3
- My Bike: ZXR400H2 GSXR750
Is it just me or is a post about lights not working from 'Dazzle' ironic or what?
Hey, i have a small mind, small things amuse it!
markzxr400l3 wrote:Is it just me or is a post about lights not working from 'Dazzle' ironic or what?
have to admit i also thought it was ironic.
- Dazzle
Hey
just hope i can get my dazzle back!
