Speedo die - ing !
- reds
- My Bike: ZXR 400
Speedo die - ing !
Just now whilst I was out - looked to check my speed and its frozen at zero - was working fine a couple of minutes before - rev counters still fine, is it just the cable that needs replacing ?
Re: Speedo die - ing !
Probably...........................
If the cable is OK then it could be the drive mechanism at the wheel or the speedo itself
Nearly certain to be the cable
- hciR
- My Bike: zxr 400
I had the drive go not long ago, take the cable off the drive and spin it with your fingers to see if you get a little flick on the speedo.
- reds
- My Bike: ZXR 400
well i thought it was def the cable - as i took it off and it was snapped - got a replacement for it and just plugged it in and still nothing - what should i look at now ???
have you fitted the cable properly as there is a notch on the bottom end that fits into the speedo drive if i remember rightly?
- reds
- My Bike: ZXR 400
yeah - got it working ! took the drive unit off and greased it up - working a treat now - although the needle is alot jerkyer than before !
