stuttering
dazah
My Bike: zxr400 l3
stuttering
Post by dazah »
ive got a l3 with scorpion endcan standard downpipes and a k&n fillter.
when the revs get high (10000ish) it starts to stutter like its going on to reserves,
it happens at most speeds but more at 100+.
i dont know if the jets in the carbs have been changed.
any help would be great biggrin
Re: stuttering
when did it start doing it?
dazah
My Bike: zxr400 l3
Re: stuttering
Post by dazah »
not to sure not rode it much this year. i thought it was the carbs were out so ive balanced them it got a little better.
when i rode it today it was a bit better as it was fairly cold this morning. :smt017
Re: stuttering
sounds like its running a bit lean fellow me'lad
dazah
My Bike: zxr400 l3
Re: stuttering
Post by dazah »
whats the easyest way to richen it up?
Re: stuttering
cutting in/out at sustained high rev's could be fuel starvation.. check your filters are clear and that the float heights arent too low.
with a KnN and a race can, it would probably benefit from bigger main jets too.
Re: stuttering
If you havent used it much and its been standing some time, then it could be gummed fuel. As Zimm says, check the the fuel filter
And of course, run some redex through and that should sort it :smt002
