so nearly everything apart from the engine wheels supsension and frame have been replaced i have dont a head gaket and camchain while i was doin the bike and i sent a set of carbs of to be cleaned and checked that i had sitting in garage
the bike will start and run at idle no probs but when you start to ride it at lows revs it will splutter and run toad until you open it full throttle and its fine if u twat it full throttle all the time
also when its spluttering if you pull clutch in the bike cuts out
to me it sounds like it running rich but i checked my plugs and they aint wet
any ideas anyone??
