Front Pads
- mycallsevern
- My Bike: ZXR400 L3 UK spec
Front Pads
I need some new fron pads but who does some good ones at a good price. Any help appreciated.
Cheers Mike.
Cheers Mike.
Rubber side down, rubber side down, rubber side down.
Re: Front Pads
deepends on what your after HH rated or just standard?
these are ment to be good
http://www.brakes4u.co.uk/products.asp?id=2672
gubbs
- My Bike: ZZR1100C3
Re: Front Pads
IIRC any 158 size will fit the L series calipers.
I have spent £37 on EBC HH ones before, but nowdays I just get whatever £10 set is cheapest off ebay.
Pads a pad.
Pads a pad.
zxr400 h2 (breaking)
zzr1100c3 (broken)
Vespa et4 (almost broken)
My FleaBay
zzr1100c3 (broken)
My FleaBay
- Full Licence rider
Re: Front Pads
I was told that HH pads are the best ones to get
Re: Front Pads
deepends on how you ride and how you use the bike, HH will wear quicker and kill the disks quicker, but will give much better stoping performace
I genraly use HH on the 750 as i only take it out when thrashing it now adays. I got about 2-3,000 miles out of the pads that are in now. There very low now tho pritty much on the metal backing!
as for the crossers i use whatever as the brakes dont work anyway lol
gubbs
Re: Front Pads
.. is the correct answer.rene wrote:i use whatever as the brakes dont work anyway lol
zzr1100c3 (broken)
My FleaBay
zzr1100c3 (broken)
My FleaBay
Re: Front Pads
Sack that lol. whatever i drive i like to know the brakes work well
Re: Front Pads
off road bikes have shite brakes for a reason, when you stick the front brakes on it genraly locks quite quickly.
And as everyone knows if you lock the front theres a good chance your going down!
Re: Front Pads
Ah there is a good chance your goin down if the front brake locks but if you dont stop before you hit that wall your defo goin down lol
Re: Front Pads
way i normaly stop is jam both brakes on so the bike goes side ways skidding though the mud, stops you rather quickly!
but if the you get stuck in a rut you very quickly become superman!
- mycallsevern
Re: Front Pads
Thanks for the help chaps.
I do have to say though, that I was messing around the other day lifting my back wheel under heavy braking, and my front wheel locked, but I didn't lose it, though I did nearly poop myself heherene wrote:off road bikes have shite brakes for a reason, when you stick the front brakes on it genraly locks quite quickly.
