If it's a timely clicking sound when the wheel rotates then it'll be a warped disk. I've had that on my VFR and when I pull the brake in it goes. After a while it'll start pulsing. If it does this then replace the disk.superman wrote:Ok folks iv had a development the noise goes when i pull the front brake thank god, so this means it aint a warped disk or the bearings so thats cool but its like a rattlin sound now somethin is loose i think.
Have you checked the correct torque on the bolts connecting the disk to the wheel? They are floating disks so shouldn't matter too much on the torque but best to check to eliminate the problem.
If its rattling then I haven't got a clue!
