Engine rattle
- insurerman
Engine rattle
Hi, I have this rattle coming from the left upper side of my zxr400 L engine and i think this could be because I let it get low on oil. The rattle doesn't seem to be there when it ticks over but it picks up when I rev it up. The bike starts fine and there seems to be slight power loss. Can anyone help? Ive had a couple of people say it culd be the rings or small end bearing or even drive chain slack, please can anyone say is there anyway i can pinpoint the problem without taking it apart just yet?
Cheers :smt013
Cheers :smt013
- BigNinjaDave
- My Bike: ZXR636, ZXR400
- insurerman
- BigNinjaDave
- insurerman
- BigNinjaDave
Here you go: http://www.zxrworld.co.uk/Manuals/H Model/ZXR400 H Chapter 4.pdf
Look at section 4.9 onwards to check the camchain tensioner.
Note: you will need a vice or something similar to compress the tensioner once you have removed it.
If the tensioner has reached its limit its time to replace the chain.
If you have to replace the chain it is very important that you ensure that all the timing marks are set before removing/installing the chain.
- insurerman
you said its coming from the upper left so it won't be the big ends? could be shim clearances? worn cam?
- BigNinjaDave
I have never had to replace the big end (sorry even as a grown man that makes me smile) so I honestly couldn't tell you what noise it makes when it is on its way out.
As long as you get the problem sorted before you ride the bike again it should help avoid any really nasty bills.
Re-reading your first post how low did you let the oil get? May be worth while taking the head off and checking the cams, rocker arms etc for any wear caused by lack of oil.
After that its time to take the engine out to see whats what.
- insurerman
Couldn't see oil in window so really low! The oil light never came on tho and someone said it does wen it gets really low. Would the cam chain tensioner explain the stalling as well coz it has started to stall wen a few people wanted to listen to it! It looks like a 5 minute job to remove the cam chain tensioner, is that right? How would i tell if the tensioner has had it?
if the oil is low the engine could get hot and start to stick which would cause the stalling but if its that bad you're lucky its not seized up, get some oil in it before you run it again, if the tensioner is worn soo much the chain may have jumped a sprocket which may cause problems, i would get the cam cover off and have a look inside.
- insurerman
- insurerman
well i wouldn't take any more advice off them if i was you, take the rocker cover off and see if you can see any pitting on the cam lobes, sounds like a good service is in order, depends how mechanically minded you are? check the valve clearances, and if i were you i'd take the engine out first, it makes it soo much easier to work on.
