bouncing revs
Banshee
bouncing revs
Post by Banshee »
i have got a problem with my idle it just wont stay where i set it one min its at 1k then its at 3.5k then back down again
and i have this loud sucking noise from the engine
anyone know what it is?
Oshar
Post by Oshar »
I had my Carb Rubbers replaced and that sorted it for me. I think they were approx £30 for a set + fitting.
richard_ha
Post by richard_ha »
Which bit is the carb rubbers? My bike's also doing this, but its going on the dyno soon anyway.
Oshar
Post by Oshar »
Not sure. Ive got a mechanic that does my work. All I can change is brake pads.
He did say that he used a paint brush around the carb rubbers that had some fule on it. That stopped the bike sucking air in through the perrished rubbers and it idled ok. Thats how he knew it was the rubbers.
good luck, Im sure someone can tell you where they are and how to replace them.
get some carb cleaner and spray it around the carb inlet rubbers (wd40 will probably do the trick too?) whilst the engine is running, if the bike revs start rising then there is a leak somewhere, could well be perished rubbers, check all jubliee clamps are tight.
richard_ha
Anyone got a photo with a nice big red arrow on pointing to these carb rubbers?
the bit between the carb and engine.
i think they're the rubber bits! :smt064
http://www.bikepics.com/pictures/485205/
In this pic they are the four black rubber bits that the carbs sit on. They look wet in this picture also :smt001
