PLEASE FORGIVE ME FOR THE HUGE POST BUT I WANT TO EXPLAIN AS BETTER AS I CAN. PLEASE HELP!
1. As stated in the title the engine runs "backfirey" throughout pretty much all the rpm range it cleans off a bit on 10k-14k. If I rev the engine with the throttle not too opened (i.e 20-25%) and steady the revs go up to the red line, but if try to open the throttle more (i.e 50-60%) the engine backfires like crazy over 9-10k rpm like its hitting the rev limiter. I don't know how to explain the noise really well and it's hard to record also as the exhaust it's pretty loud i would try to attach some clips. (it like... growly , it doesn't scream nicely). I though it was running rich and tried to re-adjust the mixture(tried pretty much everything, 1,75/2,0/2,5/3,0 turns) didn't make such a difference so i swaped the carbs with "new" ones. Mine had quite a play in the sliders and i thought they had wear on the needle jets, and needle jets seats. I striped down and cleaned the new one well(i think) didn't messed with the mixture-screws as i was afraid I won't be able to get the mixture right again like on the old carbs. Looked at the sparkplugs they seem to be decent, only number 2 a bit to rich and number 3 Maybe too lean? I adjusted the no.2 and no.3 mixtures just a tad accordingly. I was told that the carbs were balanced (so i don't think they are really really bad out of sync, i know my engine most likely has different compression on cylinders)
2. It wont idle below 2k rpm, it will stay at 1500 for a moment they almost stall at 1000. Adjusting the idle screw below 2k won't affect the idle until it the throttle bodies are almost closed and I think that's why it would almost stall.
3. Once it gets hot (middle line, first line above middle) the engine it's hard too start, some times it won't start at all. I need to give the throttle a good yank to get it started. Runs the same after it starts.
4.Lot's of pops and crackles, and some backfires when riding and decelerating.
5. Revs seem to raise kinda slow, it's not shooting on the rev range like it did when I mounted the cleaned carbs. It ran ran a lot better the day I mounted them. (maybe a week ago, the bike didn't see to much action)
6. Sometime the battery just dies, no obvious reason why. Even with the engine running, you will stop the bike and the battery would be almost empty. I checked the alternator coils(all 3 seem to be ok, in the range of 2-8ohm) all 3 are almost the same on voltage generated at 4k rpm ~49-51V
Check the voltage at the battery terminals at idle its above 14v but when reving the enigne it drops till ~13,8V. In the manual it states that it should be 14-15V all the time. The not charging issue is kinda intermitent took the next bike for the same shot trip, the battery was fine. Started with 13.01 got back with 13.40V
What i did to the engine:
-new plugs NGK CR9EK (double electrods)
-Looked at the air filter, seemd to be in a decent condition
-Played with the air/fuel mixture by opening the air intake and closing it. Took of the snorkle that is on air filter access hole. It did not help with the backfires even if I blocked the intake almost completly (just stalled the engine)
-The battery is new, AGM VARTA 8Ah Holds charge ok
-Verified all the fuses, all ok
-Tried to verify the rec/reg with the multimeter with the ohm method stated in the manual. Couldn't get a definitive reading.
-The engine was "rebuild" on a budget by me with the manual. Changed the head gasket as it was blown on no.2, 3 and 4. Head and block skimmed. base gasket replaced as well. But it seems to leak oil from the gap between the head and the block, it's not a huge leak though only gets that part of the engine a bit damp.
-I replaced the timing chain as it was worn, could've i got the timing wrong? The valves are not hitting the pistons I'm quite sure of that, but maybe they are not closing properly? I timed the engine as described in the manual. But recently I've found a post that made me think maybe i've got the cams off by 180* , would the engine run like that without blowing it to pieces? Also the timing plate with the mark and the little stud for the crank position sensor has play in it as somebody bent a bit the location pin on the crankshaft and its a bit smaller now. When mounted it I did my best to hold the plate positioned correctly on the crankshaft and dismiss the possibility of it being off by a few degrees. Also my thinking is that maybe I didn't put back the timing plate in the right spot as it has play, even though I tried to get it right. (hold it on the part of the pin that wasn't bent, as the pin is now smaller diameter and the plate has play) And maybe the spark is too soon or too late?
Maybe it needs valve adjustment? I did not made a compression test but I really want to do it now. (cold dry, cold wet and when hot) and check the valve clearances.
List to do:
-Compresion test
-Check valves and adjust
-Check coils and HT leads
https://ibb.co/hXKXDn
https://ibb.co/inzAzS
https://ibb.co/m333KS
