Hello all, I posted a greeting in the newbie section to say hi to all you fine zxr owners.  I have purchased a zxr 400 H2 and it has a problem where it does not lose revs quickly after the engine warms up. Its in the repair shop and the have stripped and cleaned the carbs and replaced the manifold which was cracked.  Unfortunately its still not running right.  They have told me the airbox rubbers are perished and mishapen so i am looking to replace this.  I have now realised just how difficult it is to get parts for it.
Will L model airbox and rubbers fit an H2?  Will L model carbs fit an H2? and if worse comes to it can I fit an L model engine?
Any thoughts or advice would be gratefully recieved and I thank you in advance for your time.
Nathan (Dursley,Glos)
													Newbie needs help with revs hanging
				Kloon
 - My Bike: ZXR 400 H2
									Cowards die many times in their lives but the valiant taste death only once.
				richr
 - My Bike: zxr 400
Re: Newbie needs help urgently
l model carbs will fit
check out ebay for rubbers and the like as lots of bikes get broken down
sounds like an air leak if the revs are hanging mine does it now and again also check throttle cables are nice and free
good luck
rich
good luck
rich
				Kloon
Thanks Rich, I am a bit concerned that a shitty seal round the airbox where it connects to the carb manifold could cause such a dramatic problem but then again I am no mechanic. I am also angry at the mechanics that are not giving me much hope, more or less saying im screwed. Just really want her back on the road. Its the black and red colour model too, dont see as many in that scheme.
				richr
 - My Bike: zxr 400
i would guess its less likely to be that seal and more likely to be one or more of the rubbers that bolt between the head and the carbs
is it that bad that you cant ride around it
can you spanner yourself at all as its not a lot of work to drop the tank and airbox off and have a fiddle yourself
are you paying by the hour as what your spending on labour could buy you some kit and theres plenty of info out there to point you in the right dirrection
h t h rich
h t h rich
- Tirpitz
 - My Bike: Kawasaki ZXR400L4
You don't need to be throwing anything away or buying new bits if your only problem is the sealing strip between the airbox and the top of the carbs.  Anything which will form an airtight seal will do - buy a tube of silicon sealant suitable for engine work from a car spares shop and run a bead of it in the groove on the carb top.  Put your airbox box on - job done.  Worse case scenario is that it comes off next time you take the airbox off, in which case just apply some more.
Hel braided hoses
Pirelli Diablos
Ohlins steering damper
A16 carbon fibre exhaust can
Nitron Sport shock
						Hel braided hoses
Pirelli Diablos
Nitron Sport shock
				Kloon
Thanks for the advice guys I have decided to put some L9 carbs on it and just be done with the old ones. Im hoping the L9 airbox will fit on my H. Maybe with a bit of bodging? any thoughts on airbox guys? Love this site so many helpful people.
Cheers, Nathan
									Cheers, Nathan
				Kloon
richr wrote:l model carbs will fit
good luck
rich
All the cables are free and the choke plate etc according to my mechanic. Thanks for the tips Rich.
				richr
 - My Bike: zxr 400
had a word with my daughter today about thr revs hanging and she said both her bikes did it
she said on hers if she stopped put it in neutral and ease the clutch in and out a couple of times the revs would drop
she said they all do it
one thing i would have checked is the carb ballance as this makes a big difference when set right
h t h rich
ps might see you around as im in cheltenham
h t h rich
You will need to chop an L box to make it fit then patch the holes you made with sealant and plastic removed.
Fit FCRs and be done with it
I have my H2 airbox some where
Sounds like you have gone to a shop that just want the easy solution and quick quid bike service.
In CVKs try replacing the springs inside the diaphragm as they have been doing a lot of work for many years so could be tired - this might help the hanging revs.
