Hello
Posted: Tue May 10, 2011 4:26 pm
I know this deosnt really fit in a ZXR forum, but anyway...
Hello..
Just wanted to introduce myself, Just got a Gpz400r 1986 I believe a grey import (first bike)... It was sold as a bit of a duff horse that needs flogging to make it work, Its currently being stripped down and poked at with a stick. Current problems I've encountered are Rocker gasket seal damaged (attempting to locate a new one no real joy), W alloy frame piece from front of bike which helps locate the radiator is split at the screw joint (again no joy yet finding a new piece) Fame is being resprayed as best as possible in spare time.. All usual parts attempting to give a good spray to clean up rust and reproof for Northern Irelands lovely sunny weather.. So far have fittend a Knn air filter, fuel filter, changed all oils, resprayed a new radiator and fan and attempting to look at the wiring loom and repair all the mangled parcel/masking tape problems..
Will start to post a few pics of the current state of bike and progress.
But if anyone here has ever owned one and would like to pass on any snippets of wisdom i would greatly appreciate it.. Also thanks Cargo for your advice..
Regards
Monty
Hello..
Regards
Monty
