just fitted some led indicators and when i indicate left all 4 indicators light up and dont flash... and the same when i indicate right all 4 indicators light up... ive bought a 3 pin led relay but need to know how to wire this in... can anyone shed some light?
the relay that is behind the left side panel has 4 wires going to it 1 x live 1 x ground and 2 others, i unpluged the OEM relay and wired the live to the live on the A/M relay and the ground to the ground on the A/M relay and the connected the 3rd pin on the A/M relay to one of the other wires on the bikes relay plug and the headlight started to flash... so i then connected it to the other wire and the relay just kept clicking... what am i doing wrong?
led indicator trouble... help needed...
- hainesz
- My Bike: 1994 zxr 400
[color=#FF0000]...Burn Rubber...Not Your Clutch...[/color]
- hainesz
Re: led indicator trouble... help needed...
right ive just realised ive been a idiot... lol... i wasnt even at the right relay its the one on the right hand side... but ive now got another problem the OEM relay has 2 pins but plugs into a 3 pin harness plug now i plug in my new relay and when i indicate left all 4 indicators flash and then the same if i indicate right... what do i do???? urgent help needed.... im calling for all the zxr guru's help...
