The wiring from the pick up that cargo is suggesting is an easy check, your mechanic should not be charging much to look at this, or if this is the problem (touch wood) to fix it.Skins62 wrote:toad pal my wife is on all them plus fentinol patches I sympathise with you I really do ,the bike is running perfect temp and yes totally balanced all the carbs so maybe try the wiring ,but that's a needle in a haystack thing isn't it ,and I'm quickly running out of money
One other thought, what oil is in the bike, if the oil was poor quality or worse, the wrong oil, how long before the engine begins to object and run like toad.
Talking of touching wood, has you girlfriend read your post yet Ross?
