ZXR400?
Re: ZXR400?
Brushed ally effect would look good i think.
Mori Man
Blingmeister
Blingmeister
My Bike: ZXR400J2
Bling Bling
Post by Mori Man »
Had a bit of time today to go out and do a bit more work on the frame.
Trying to organise my time that at least go out for an hour each day to help progress :smt017
I know once I have a rolling chassis I am only looking at a weekend to then get everything else on with a hopeful Sunday evening fire-up :smt001
But this bit always seems to take for ever but a bit more progress done today.
started to sand out the rough cast, want to avoid painting as it's not part of my plan/image of the bike, things are starting to shape up though:
Then I accidentally put the felt disc onto my angle grinder and it found it's way to the cutting/finishing soap and this happened :smt005
By no means perfect as all I am doing is polishing up the factory finish as don't have the time to spend smoothing out the beams - maybe next strip down I'll take the time and then get it anodized :smt007 but for now this will do.
Only thing is the ding in the frame is now more noticeable but ultimately a steering damper is going to take away the bad look :smt002
Can still see the factory swill marks but I ain't entering this into a show, it's to be used :smt003
Swinger is getting it next :smt004
Re: ZXR400?
Id say you might regret polishing it, but you dont get the shitty weather and winter we get here so maybe itll be ok and wont need so much upkeep?
Mori Man
Blingmeister
Blingmeister
My Bike: ZXR400J2
Re: ZXR400?
Post by Mori Man »
RedexRobB wrote:Id say you might regret polishing it, but you dont get the shitty weather and winter we get here so maybe itll be ok and wont need so much upkeep?
Don't get the shitty salt on the roads !
Would actually consider getting it chromed as the swinger and rocker cover on the Rex cleans up like new every time I give it a wipe over.
However, I do like the idea of having it done Champagne Gold anodized the same as the front fork tubes which i would also get re-done at the same time :smt007
Should be fitting the headstock bearing shells next week and then triples :smt001
Got to decide , drop frame on engine and bolt in or make rolling chassis and lift motor in :smt017
Vard66
Re: ZXR400?
Post by Vard66 »
Gonna polish up the whole frame, including the head tube, or just keeping it polished to the weld points, Drew?
Vard.
_________________
1997 Volvo 850 R
Mori Man
Blingmeister
Blingmeister
My Bike: ZXR400J2
Re: ZXR400?
Post by Mori Man »
Vard66 wrote:Gonna polish up the whole frame, including the head tube, or just keeping it polished to the weld points, Drew?
The two sections shown will get polished, the inserts are having something else done :smt003
Head tube and all the inner stuff will be Black along with some parts of the swinger.
You'll see why once it's a rolling chassis :smt001
Vard66
Re: ZXR400?
Post by Vard66 »
Mori Man wrote:You'll see why once it's a rolling chassis :smt001
Now there's a hook line!
Alright, I'll wait.
Vard.
_________________
1997 Volvo 850 R
Re: ZXR400?
makes me wanna go polish my frame now! just know what a pain it is to keep it polished. :smt012
Mori Man
Blingmeister
Blingmeister
My Bike: ZXR400J2
Re: ZXR400?
Post by Mori Man »
Made a start on swinger now, it got the stiched mop 1st and that's removed more of the factory swirls.
No pic's yet - been running about daft most of day and taking pic's of this:
Re: ZXR400?
God, that looks good!
arkell
Re: ZXR400?
Post by arkell »
^^^ awesome :smt003
Mori Man
Blingmeister
Blingmeister
My Bike: ZXR400J2
Re: ZXR400?
Post by Mori Man »
Today the lights arrived for my winter project once the bike has been up and running for a while (NB. Build one is to get it registered, taxed,insured and MOT'd).
Can't decide on making them flush with the centre of the nose cone like this:
or to make them flush with the outer edges like this:
So
This Or That
Some random shots
I like both , bugger :smt017
I'll get some high density Black foam and make damper rings for them so they are sealed into the sockets. I'm going to build a carriage inside to mount them on and make it possible to adjust them too.
Have to stress these are purely cosmetic - I do very little night time driving so both will be set on a low beam pattern.
The outer ring is White LED and they will come on when the bike fires up , the fish eye lights are 6000K 35W HID units and they'll run off the switchgear.
MM!
Re: ZXR400?
Personally they look better sunk in to me, stuck out they make it look like a gold fish.
Mori Man
Blingmeister
Blingmeister
My Bike: ZXR400J2
Re: ZXR400?
Post by Mori Man »
RedexRobB wrote:Personally they look better sunk in to me, stuck out they make it look like a gold fish.
That's kinda why I like them - that "eye popping" experience :smt003
But sunk in looks more menacing :smt003
I keep switching them just now as i still have it set up in the living room - it's not helping :smt005
Re: ZXR400?
maybe set them even further back, space allowing, and the inner rim of the headlight hole painted black?
