Clutch Issue
Re: Clutch Issue
You can remove the bearing in the middle thaty will allow the rest to come out
MillaMeter
Re: Clutch Issue
Post by MillaMeter »
cargo wrote:You can remove the bearing in the middle thaty will allow the rest to come out
Sorry to ask so many dumb questions, but how do I remove that bearing? I see 2 holes in it... I read somewere (was on a ZX1400) that you put a 4mm bolt into it and pull it out that way, will that work or? I see what you mean though, pull the bearing out so the housing will move over to the left so it can be taken off.
Will I still need to swap the housings over? Will save me alot of time and effort if they're the same.
Regards
Rich
Re: Clutch Issue
Can't help you with that one never seen a ZXR 400 slipper clutch and don't much see the point of one never once on my road and race ZXRs have I felt that I needed one.
