I've come to the 'green' side (with questions)
Re: I've come to the 'green' side (with questions)
hi castrol/jeppo ..
the base gasket seals the cylinder block to the crankcase, you just use silicon to seal the joint instead of the gasket.
its a personal thing as to wether you fit the gasket or not, some tuners leave it in, some DIY'ers leave it out as a cheap (free) performance mod .. although how much difference it makes is probably a small percentage of cock all
Caz
My Bike: GSX-R600 K4
Post by Caz »
Jeppo wrote:Another thing, is there a simple way to raise the back end a little, I'm not that tall (5'10) but im used to bein a little higher off the ground
stick a spacer above the rear shock - be warned though, this will make the bike turn in very quickly.
GSX-R600 K4
ZXR400 H2
Commuter: Gilera Runner 180SP
