Restarting Problem
Re: Restarting Problem
having had 2 cases of HGF with my mg rover! i know from experience that they only need to be skimmed if they have warped, due to using the engine when it overheats.
a very crude way to check if the head is warped is to use a metal rule and a torch, lay it across the head and if u can see any light under rule then the head is warped and needs skimming
or a sheet of glass and some water. and i don't mean patterned glass.
