Its much easier with the rad completley off, however you can undo the lower fixing brackets and do it that way, with an adjustable spanner with the angled socket points you can manage it.RedexRobB wrote:Dont think its that hard, will be akward with the radiator in the way so you might need to drain the coolant and remove it to do it, otherwsie you could end up damaging the back of the rad....
my new micron Stainless down pipes, with Akrapovic titani
mongo
Re: my new micron Stainless down pipes, with Akrapovic titani
- BANJO
- My Bike: ZX4R NINJA
Nice thanks for that i will take the rad off.
dean
dean
you'll have a lot more fun trying to get them rusty bolts of the studs! manged to snap oh so many of them!
- BANJO
- BANJO
a bit better vid
[youtube]<object width="425" height="355"><param name="movie" value="http://www.youtube.com/v/U0M11BB7uBE&hl ... ram><param name="wmode" value="transparent"></param><embed src="http://www.youtube.com/v/U0M11BB7uBE&hl=en" type="application/x-shockwave-flash" wmode="transparent" width="425" height="355"></embed></object>[/youtube]
dean
dean
- Scott221
- Restricted
- My Bike: ZXR400 L9
Find out where its blowing from, check your gaskets.
- BANJO
Done that mate. It was No.1 So i took all the downpipes off and put them back on. But now No.2 is blowing not as much and it sounds so much better.
dean
dean
tobomoto
- My Bike: zxr400l4 zx7r
can you tighten them up any more? if not use earplugs or a mp3 player. works for me! did the pipes fit into the collecter ok? i had to heat mine up and bend them to make them fit.
- BANJO
yeah nice and easy. I will try and do it up some more but I'd put the rad back on i will try tomorrow after work
dean
dean
- jake
I dont use gaskets on either of my systems dude, the micron same as yours there and the beet. I dont need to have them bolted up mega tight, just nice and even.
Im not saying it right, or that you should. But it works for me ok.
- BANJO
yeah mate thats what i did my mate said i should have done them all nice and even. 1 turn on each nut and it has worked just need to do No.2 up a bit more. will just have to move the rad
dean
dean
- BANJO
stopped it blowing here is a vid
[youtube]<object width="425" height="355"><param name="movie" value="http://www.youtube.com/v/aiNy7EvdFnA&hl ... ram><param name="wmode" value="transparent"></param><embed src="http://www.youtube.com/v/aiNy7EvdFnA&hl=en" type="application/x-shockwave-flash" wmode="transparent" width="425" height="355"></embed></object>[/youtube]
what do you all think ?? I think it sounds like it's a bigger cc bike
dean
dean
sounds nice fella but then avvy cans always do. Wait till you acutally ride it under load will sound even nicer then
- Scott221
- Restricted
rene wrote:Wait till you acutally ride it under load will sound even nicer then
Get somebody to video you flying-by. I couldn't believe the noise mine made when i saw a video of me.
- BANJO
been playin loads with the bike put my K&N filter in and the bike was missfiring at about 8000RPM
so i put the stardard filter back in and it was still missing but at about 4/5000RPM so i took the filter out and just put the mesh bit that the filter sit's on back in the air box and the bike now goes like f**k. But it still need a tune as i've been told it's running to rich if it now run's ok with no air filter.
here is a vid of a slow fly by i've not got that much of a road to open it up but it does sound well NICE
[youtube]<object width="425" height="355"><param name="movie" value="http://www.youtube.com/v/x3r9GGNGY1Y&hl ... ram><param name="wmode" value="transparent"></param><embed src="http://www.youtube.com/v/x3r9GGNGY1Y&hl=en" type="application/x-shockwave-flash" wmode="transparent" width="425" height="355"></embed></object>[/youtube]
part 2
[youtube]<object width="425" height="355"><param name="movie" value="http://www.youtube.com/v/Wxpe3xy6WHk&hl ... ram><param name="wmode" value="transparent"></param><embed src="http://www.youtube.com/v/Wxpe3xy6WHk&hl=en" type="application/x-shockwave-flash" wmode="transparent" width="425" height="355"></embed></object>[/youtube]
dean
part 2
dean
