Hot Starting Problems
SplaTZXR400
My Bike: ZXR400
Post by SplaTZXR400 »
wot same problems as mine, i must say this is a fuk**kin ghost! i have searched every inch of wire on that bike, checked all earths n joins, no problems! i mean fu*k me sideways, upside down and back to front! i cant say how fustrating this is! i cant see any more broken wires ave cleaned all contact etc. last resort i think is to change components as that is the last thing it MUST BE. 1 idea i have tho is, coz it sounds like it runs on a cilender or 2 less, i think. iv added a wire off the coil input -> to the frame. with a bulb in the middle. the idea being, that the bulb should light wen it fires but wen it splutters and dies it should give me a good idea which if any are faulty and not firing. then trace that wire back. not tried it yet but should work.
diesel
My Bike: Zx7r
Post by diesel »
mines the same. well embarrasing as sometimes it backfires and makes all the oldies jump hehe. not as embarrasing as leaving a front disc lock on at a bike do and trying to go. :smt009
Quicker Than Yngwie
SplaTZXR400
My Bike: ZXR400
seems a few people are having these problems yet it seems to be a problem without a soloution, i tried the bulb thing, it didn't work lol, but it did prove that a live 12v short of the earth wil produce the same effect. whether this means a live short in a component.but only affected by water mainly, i dont know.are some bikes just tainted or cursed?
tk400
My Bike: ZXR400 , ZXR950
Post by tk400 »
you may want to take a look at the fuel pump solenoid.....it has two inputs that it uses to determine fuel pump state.....one is a starter input and the other is the ignition input from one coil......if either of these inputs is not functioning fuel pump wont run.......
cheers
SplaTZXR400
My Bike: ZXR400
Well the cutting out seems more electrical that fuel related but i see wot u mean tho. 2 of the coil wires both go straight to it, i assume you mean the relay ye? so if thats buggered coz of the amount its been dropped, i spose that could cause problems, if there was a short. i might look into replacing it. relays dont seem to be expensive, but if i do, hope this fixes things. so annoying 2day couldn't let it idle going to work coz it would die every time.
SplaTZXR400
My Bike: ZXR400
you'll never fukkin believe wot guys. there was a wire bridge from the live brown wire to the rear brake switch, bridged across the red wire on the fuel pump??? i reckon its that polish 'mechanic'/muppet who owned it before me, he's fukked alot up on this bike.
so its all sorted now then mate??
SplaTZXR400
My Bike: ZXR400
not quite.think im gettign there slowly, it stil cut out but iv literally just found out like 2 mins ago that the black wire to the coil is broken inside, n the engine like stutters when u move it. not checked the other 3 yet but hopefully this is related to the problem.
