snapped cam chain, help :(
- My Bike: zxr 400 L8
Re: snapped cam chain, help :(
ok i get ya, its just that im new to getting info from forums and thort it was better to split the topics up, but from naw on i know to keep it together.
after taking the chain guides out i have found what looks like damage, but im not sure. so if anyone could confirm they are damaged it would be a great help.
Classic delamination of the tensioner blade......replace it.
And since your in there anyway a new camchain would be a good idea
Thanks mate, Il get them bought.
Tryed getting the timing plate off today and i have not got it off yet, If someone could give me a tip on how to get it off that would be great
undo the bolt and lift it off
do i need any kind of special tool to keep the crank from turning or can i just put a 19mm spanner round it and use an allen socket to undo the bolt ?
Chears
Chears
that'll do the trick nicely
a rattle gun is good too
actually now that i think of it it might be a bad idea to use the 19mm spanner to hold it cos the little split pin that locates the rotor might get damaged.
So rattle gun is best or find some other way of stopping the engine from turning....................in gear and back brake on
Ok iv rebuilt the engine and its back in the frame. I have just got the engine running but it sounds a bit rough. It sounds like its got a rattle, but iv changed the cam chain and guides, Iv also checked to see if its still under tension and it is. Does anyone have any ideas on what it could be ?
Did you remove all the valves to check they were straight or just the ones you could see damaged ?
Sometimes you can capture the camchain when installing meaning it has slack at the bottom that is not taken up by the tensioner , another possibility is you have been given the wrong camchain and it has too many links.
Yea i took out every valve. also the cam chain never realy felt too big and is still under tension. could it be caused by a couple of valve shim gaps being out of tolerence ?
have you timed it properly .................timing marks all lined up correctly ?
If it was a tooth out it will start and run but sound like a box of nails
hmm yea possibly, il take the cam cover off and check tonight
Well after 7 hours and lots of coffee i think iv sorted the nasty rattle out. iv gone over all the valve shims and corrected them (they where a mess). it sounds a lot better naw.
